I cant see anything similar near the ecu. I need a definite location form one of the rs2 owners to be sure if my car has one or not.
In the meantime while you wait for an RS2 owner to point you to the exact location, you *could* follow the green vacuum/boost hose from the intake manifold "T" towards the ECU. You will find the moisture trap (aka "fuel condenser") along the way. Or at least you should. Who knows if somebody removed yours.
In another thread, Mcandmar has suggested: "Moisture trap is behind the left hand side kick panel, i.e. remove the side pillar trim below the glovebox."
This is a left hand drive car so the trap is behind the driver side kickpanel. First remove the bonnet release handle and then pull off the kickpanel...
S2 Avant SleeperWagon 570hv and 765nm on 2,2bar/E85
Never thought about this. Will check definitely. Hope I find it.
