Moisture trap Rs2
  • murat
    • Oct 2005
    • 167
    • Country: Turkey
    Moisture trap Rs2
    I am trying to find moisture trap in an rs2. Any info is appreciated. I tried searching but could not find any exact information for rs2
    I have a green line coming directly to ecu map sensor in passenger side. another black one is going to aircon.
    Murat
  • mcandmar
    • Apr 2004
    • 5118
    Follow the green line, its behind the plastic trim at the side of the foot well.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • murat
      • Oct 2005
      • 167
      • Country: Turkey
      do you mean near altitude sender?
      Murat
        Should be very close to the ECU. Probably in a grey foam "case". Two hoses on top. One in, one out, like this UrS6 one.
        • murat
          • Oct 2005
          • 167
          • Country: Turkey
          I cant see anything similar near the ecu.
          I need a definite location form one of the rs2 owners to be sure if my car has one or not.
          Murat
            Originally posted by murat
            I cant see anything similar near the ecu. I need a definite location form one of the rs2 owners to be sure if my car has one or not.
            In the meantime while you wait for an RS2 owner to point you to the exact location, you *could* follow the green vacuum/boost hose from the intake manifold "T" towards the ECU. You will find the moisture trap (aka "fuel condenser") along the way. Or at least you should. Who knows if somebody removed yours.
            In another thread, Mcandmar has suggested: "Moisture trap is behind the left hand side kick panel, i.e. remove the side pillar trim below the glovebox."
            • murat
              • Oct 2005
              • 167
              • Country: Turkey
              I already did.
              Greenline comes from firewall direcly to the ecu.
              I found another greenline, but it goes inside the chassis, so I cannot check where it is going.
              Murat
              • dobbin
                • Jan 2011
                • 164
                rs2 trap
                on my rs2 its in passenger footwell, remove left panel below glovebox should be right behind there as in pics above if not probably been removed.
                • Vauhtiveikko
                  • Jun 2010
                  • 250
                  This is a left hand drive car so the trap is behind the driver side kickpanel. First remove the bonnet release handle and then pull off the kickpanel...
                  S2 Avant SleeperWagon 570hv and 765nm on 2,2bar/E85
                  • murat
                    • Oct 2005
                    • 167
                    • Country: Turkey
                    Never thought about this. Will check definitely. Hope I find it.
                    Murat
                    • saltinot
                      • May 2004
                      • 1946
                      When/If you do, would you mind taking a picture of how it is mounted. I don't have a reference for this and a picture would be a great help.
                      • murat
                        • Oct 2005
                        • 167
                        • Country: Turkey
                        finally found it.
                        For future ref,
                        moisture trap in a LHD RS2 is located in the drivers side kick panel.
                        and here is the pic
                        Murat
                        • murat
                          • Oct 2005
                          • 167
                          • Country: Turkey
                          by the way, thanks everyone for help.
                          Murat
                            finally found it. For future ref, moisture trap in a LHD RS2 is located in the drivers side kick panel. and here is the pic
                            Yay!! For future reference, I am borrowing your photo for a consolidated moisture trap post (UrS4, UrS6 and RS2/S2).
                            Need a photo of the location in a RHD S2/RS2 though. Folks?
                            • mcandmar
                              • Apr 2004
                              • 5118
                              I knew it was there ...sorry for the confusion i assumed Audi would have moved it to the other side of the car with everything else.
