RS2 mods on a 200k engine?
If you are cleaning the sump it is not much effort to pull a cap and see if the bearing looks worn.
Personally if its running ok I would just bung it on and see what happens as you have a spare engine.
Once you start building an engine it adds up quick, though you can build a bomproof engine for the next 200k.Current-2004 Impreza PPP wagon
Sold ABY-stockComment
I recon you should check the mains/big ends if you have the chance. A compression/leakdown test will tell you enough about the top end and if anything is going to go on a 200K engine it will be the shells from what I've seen. With the extra load it may start to knock before anything goes, giving you chance to get it sorted before it's a total failure.91 Modded 3B
14 A6 Avant Black EditionComment
this is what i was thinkingIf you are cleaning the sump it is not much effort to pull a cap and see if the bearing looks worn.
its an AAN head i found out,not that it makes and difference.
i hear what everyone is saying about checking it thoroughly etc but i have been looking at it today and it is in such good condition,cambelt recently done lovely clean water/coolant.
spent most of its life unchipped etcComment
Hey dude, Just go for it or you'll spend millions on replacing everything down to the last molecule. These machines are hard as nails.
On a different note, a20vaa has just had its 200 thousand mile birthday, got it new suspension and did the top end - It still passes the emisions test no bother.sigpicComment
Still miss that car got some great pics of it still I used to have black rear treser style lights on it but took them off as didn't suitComment
