Finally got all my intake plumbing 100% - no leaks - or at least I thought so. Tested with bungs and compressor and found a leak on the i/c outlet.
However, under driving I can only get ~1.1 bar boost max (third gen' ABY Homefry so expecting 1.4 bar).
It 'feels' as though the boost is actually being limited to this value, not leaking as such. Car pulls great up to this value and then just sits there (does not leak away until 4,800rpm+).
When I did have leaks I could get 1.3-1.4+ bar but boost would fall away quickly - this feels very different in driving now.
Any thoughts as I'm starting to lose patience but suspect the '5cyl specialists' would struggle to track it down so nervous about large bills from the qst's of this world.
Thanks in advance.
FWIW - bypass valve, wgfv, throttle pot, air temp sensor, water temp sensors, oil temp sensor and plugs all nearly new. Fuel filter replaced. All small bore hosing is silicone, + samco kit. MAF and contacts cleaned. WG diaphragm tested ok.
Thanks in advance.
