ADI not looking good for me :(
  • montez
    • May 2010
    • 396
    Finally got the car back together (10:30pm), started first time and only had a small water leak to contend with. All fixed up bled and fluids topped. Went to petrol station to put air in tyres and some fuel in.
    Pulled out the petrol station and bang, the engine cut and there was a massive shunt along the drive train.
    Initially I thought **** the cam belt has gone or something similar, popped the bonnet and all seemed fine. The car started fine and sounded sweet as a nut on idle, got in to drive and the engine kept cutting out.
    I am thinking that I may have connected something in the wrong place and it a sensor throwing a fault. I have found this not connected to anything but do not have a clue what it can attach to?
    I tried swapping it as I thought I had two the wrong way around and it cut all fuel so I am hoping this is the ******.
    1991 Audi S2 Coupe
  • Drummer87
    • Oct 2009
    • 1644
    • Home: United Kingdom Current: Scotland
    Pos??
    • montez
      • May 2010
      • 396
      Pos???
      1991 Audi S2 Coupe
      • targus
        • Sep 2012
        • 185
        • Home: United States Current: England
        Temp sensor on back of head or after run pump? The power output stages are bigger plugs
        • montez
          • May 2010
          • 396
          It is a 3b no power output stage, did not think it is after run as not long enough
          1991 Audi S2 Coupe
          • montez
            • May 2010
            • 396
            Feels like either intermittent fuel cut or ignition cut.
            1991 Audi S2 Coupe
            • BrianSmith_S2
              • Jun 2005
              • 1342
              • Home: Northern Ireland Current: British Antarctic Territory
              Isv?
              • montez
                • May 2010
                • 396
                I think the isv is light blue
                1991 Audi S2 Coupe
                • targus
                  • Sep 2012
                  • 185
                  Check the leads all on ok and not caught
                  • SteveH
                    • 4460
                    It looks like the water temp sensor plug from the back of the head. Check for big boosts leaks like a clip that may have been overlooked being tightened up. If you get it fixed early enough you should still make it down to ADI for the afternoon.
                    91 Modded 3B
                    14 A6 Avant Black Edition
                    • montez
                      • May 2010
                      • 396
                      The coolent temp is white on back of head, tried swapping and the var would not start, maybe evap?
                      1991 Audi S2 Coupe
                      • montez
                        • May 2010
                        • 396
                        No boost leaks, got 13 bar pressure per cylinder so head is ok, will try and find vagcom leads
                        1991 Audi S2 Coupe
                        • Vauhtiveikko
                          • Jun 2010
                          • 250
                          That sort of plug goes also for lambda and attaches to the lambda harness near the driver side firewall...?
                          S2 Avant SleeperWagon 570hv and 765nm on 2,2bar/E85
                          • Sleeper_Avant
                            • 2372
                            could that be the gearbox pickup plug?
                            1993 URS4 Avant Emerald Green 350+bhp
                            1991 Ford Sierra Sapphire 4x4 in Magenta
                            BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
                            • denniselbows
                              • 740
                              I'll have a look in mine in a bit to see if I can find that plug goes just got to eat me breakfast first.
                              never set your expectations to high that way you are never disapointed
