Waste Gate problem :(
  • Ski
    • 2591
    One of the waste gate nuts twised off / snapped off on me while i was tightening it..
    question 1 :
    can I run with 1 less bolt ? (i think theres 4 or 5 lleft)
    question 2 :
    Is it part of the lower wastegate (i.e. will i need a new wastegatee ?) or are the bolts seperate ?
    ABY Coupe
  • SteveH
    • 4460
    You may be ok if the cap doesn't leak boost. Unfortunately, the wastegate is only available as a complete unit and that's megabux. I'd strip it down and try to replace the broken stud.
    91 Modded 3B
    14 A6 Avant Black Edition
    • Ski
      • 2591
      Any suggestions how i can replace the broken stud? An engineering company?
      ABY Coupe
        chop old one off, drill the hole have it re tapped and a new threaded bar put in.
          Did it break right down the bottom? ie is there anything left to get hold of if you take the cap off again?
          • Ski
            • 2591
            Yes theres lots left.. it twisted off right at the nut. I didnt even put much pressure on it..
            it seems to be holding fine (no leaks)
            ABY Coupe
            • Erikb
              • Jul 2004
              • 648
              Exactly the same happened to me. I had luck I could get hold on a old wastegate complete with cap, cooling etc for 10 euro. I took two studs out and replaced them. Maybe I have some studs left.
              Getting everything sorted out for my 5++ hp project
              • Ski
                • 2591
                so you can replace the studs?
                Erikb if you have a stud free I would do backflips to get one!
                ABY Coupe
                • S2 Ant
                  • 3682
                  Have seen some wastegates going on the Bay of E lately, not sure if there are still any on there tho... worth a look tho
                  Ant
                  2011 Kawasaki Z1000
                  • Erikb
                    • Jul 2004
                    • 648
                    Ski,
                    I have to check, but I think I will have some left.
                    I will let you know as soon as possible.
                    I did drive 2000 km with one stud less, it wasnt loosing pressure. But mine isnt tuned.
                    kind regards,
                    Erik
                    • Ski
                      • 2591
                      Thanx Erik, much appreciated
                      ABY Coupe
                      • Erikb
                        • Jul 2004
                        • 648
                        ok, ski I have three pieces left. I will try to get them loose and send you one. Please send me your address with a PM.
                        • Ski
                          • 2591
                          Erik you are a star!!! I will kiss your feet if I ever meet you!
                          ABY Coupe
                            OK now softly softly, dont just try to undo the stud with mole grips, you want to soak that baby in Plus Gas for a while first, then go easy, if it doesn't just twist out you could try a LITTLE heat from a butane torch, dont melt the alloy.. remember to hook the diaphragm out of the way of the flame!! If it doesn't come leave it to soak a bit more.
                            • Ski
                              • 2591
                              thanx for the wise words, I will follow this method like a bible!
                              ABY Coupe
