Have no clutch on my 20v ur coversion! Plaese help!
With the clutch assembly bolted to the crank.
Measure from the inside of the spigot bearing to the tip of the clutch fingers then do the same from the end of the gearbox shaft to the release bearing
maybe a very silly question but does the driveshafts and prop shaft have to be connected to test it?
The car will not work as a fwd with the prop removed if that is what you mean? (unless you lock the centre diff). If the diff is open and a wheel is off the ground or a shaft removed all drive goes to the point of least resistance.
I'm just thinking if drive shafts and prop shaft is not conected it's normal that you can engage into gear while engine is running
I have just read back through the thread. I thought the issue was you couldn't get it to take gears. However you are saying you can get gears even when the clutch isn't pressed?
Have you had somebody check to see if the gearbox output shafts stop spinning when the clutch is pressed down but still in gear?
One more thing. Do you have to force the slave cylinder in or can you comfortably push it in by hand? If you do have to force it in then you need to try a shorter rod as it will be pushing on the pressure plate fingers.
Ok guys, been in the garage for last few days trying to figure it out,
AND I DID!!
The driveshafts and prop shaft HAVE to be connected, or you will engage in any gear while engine is runing
Without pressing the clutch pedal!!! And make you think that is something wrong with clutch or gearbox or another 1000 thoughts why?
Thank you very much for all who helped
And and ? Welcome to the QUATTRO world
