Rs2 Turbo And Rs2 Hybrid Turbo
    Seems to me in the last couple of years half the Garretts bought and fitted on forum cars have spat their guts out in the first few thousand miles. My perception is their build quality & reliability is crap. Rare you hear that about 20 year old 150k mile KKKs let alone new ones. My 2c
    • A80Avant
      • 10873
      • Country: Greece
      Partially true. If that was the case though all the ones you have heard that blew up would have been refunded and replaced. If that wasn't stated then its likely that they may have been used inappropriately. Quality of parts have stricken all makes. If a kkk turbo is badly rebuilt or with china made parts then you would expect similar results.
      Turbochargers are dispensable items when high boost applications are used.
      How many rs2 turbos you know lasted 100k kms with 1.9bar of boost dropping to 1.4 ?
      If you use a garrett in spec it should last for many years and miles.
      sent with Nokia 5110
      • david
        • Oct 2008
        • 1268
        i believe rs2 kkk will outlast a garrett turbo anyday even at 1.9bar boost
        [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
        RS2 VOLCANO BLACK] soon to be broken to bits
        • 20Vcqdriver
          • 829
          And the best place to get an RS2 turbo is....???
          1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
          • Acidburn
            • 13459
            there was a couple in the for sale thread on here. If you can't get hold of them it might be worthwhile asking hoffer about his hybrid turbo's.
            An rs2 turbo will last for ages up to around 1.9bar, over that shortens the life quite a bit.
            • piotr
              • Jul 2012
              • 1470
              • Home: Poland Current: England
              #21
              Thank you guys for your advice and opinions and i would like to ask for more as i still don't know what will be better ?genuine standard rs2 or hybrid???
                Just keep an eye out and see what comes up. I got lucky and picket a complete upgrade kit for sensible money.
                The RS2 kit is all bolt on and it's easy enough to get the ECU sorted with a decent generic map or live map.
                If you decide that you want a hybrid RS2 then you're as well starting off with an RS2 turbo and getting it upgraded.
                • Acidburn
                  • 13459
                  depends if you want to pay for a remap.
                  Its easy to get chips for a stock rs2 turbo and that will be more than enough for most people.........BUT..... if you can get as andy/rusty says a complete kit or a turbo with a chip then thats an option.
                  • A80Avant
                    • 10873
                    • Country: Greece
                    #24
                    that is a statement that cannot be verified unless we do an audit at least of the forum member's experience. You cannot assume the KKK are more robust when the vast amount of S2/RS2 owners keep their car's stock and dont tamper with them.
                    On the subject though, a down to earth stock rs2 setup is more than enough for most. Dont take my experience as standard as it isnt!
                    • diogocartier
                      • Jan 2012
                      • 151
                      • Country: Brazil
                      #25
                      Guys,
                      do i need to replace the OEM S2 Fuel injector with the RS2 turbo?
                      rgds!
                      • rynaqui
                        • Mar 2012
                        • 2752
                        • Country: Malta
                        #26
                        Yes, standard S2 injectors will not flow enough for RS2 turbo.
                        1996 S2 ABY Silver
                        • driftin jo
                          • Sep 2007
                          • 2222
                          Originally posted by diogocartier
                          Guys,
                          rgds!
                          yes, you need RS2 injetors or bigger.
                          • rynaqui
                            • Mar 2012
                            • 2752
                            • Country: Malta
                            #28
                            Not sure if fuel pump would need to be changed as well? If anyone can confirm
                            1996 S2 ABY Silver
                            • Drummer87
                              • Oct 2009
                              • 1644
                              • Home: United Kingdom Current: Scotland
                              #29
                              And I got one rs2 pump ready to sell
                              • driftin jo
                                • Sep 2007
                                • 2222
                                Yes, you need to change the fuel pump,
                                a new S2 fuel pump would be on the limit
                                with an RS2 turbo and an old one would
                                not be advised at all.
