Another allternative aux radiator plug I found out today= engine oil pan plug
  • Josh-stateside
    • 741
    Hi guys
    The topic basically explains all the goods. The oil pan plug works fine for plugging the aux radiator hoses(top and bottom). I only wish I figured this out before I ordered the forge motorsport by pass vavle plugs.
    Josh
    Thats a top bodge Josh !
    But lets remind newbies that you mean *spare* sump plugs
    • porkkis
      • 1994
      Errm. The threaded part as a plug? It will most certainly leak!
      • Josh-stateside
        • 741
        Well if it leaks i will let you know(in my opinion it will not leak). I have some nice heavy duty clamps on it. However this is the second coupe and the fuel pump died and the head gasket is blown. So it will be awhile before she becomes alive again.
        If it does leak it's a nice temporary solution to a bad aux radiator. On a side note, exhaust gas is getting into my coolant system and that pressure has yet to pop the plugs or force coolant throught them. However most of the coolant is making it's way into my f'n downpipe.
        Disclaimer.. What you do with your cars is your digression.
        www.forgemotorsport.com if you want by pass vavle plugs.
        Josh
        • S2 Ant
          • 3682
          Another i found out about over the weekend is to chop up your old rear ARB... fits perfectly... now a couple more S2's with this bodge in place
          Ant
          2011 Kawasaki Z1000
          • Billman
            • 4129
            What are these parts? Any pics?
            Go Holset or Go RS4
            • jameswkr
              • 538
              Go to your local plumbers if you want to do this mod.........see previous threads.
              • Doug_RS2
                • 3847
                Front S2 ARB
                • S2 Ant
                  • 3682
                  Oops my mistake
                  Works well tho!
                  Ant
                  2011 Kawasaki Z1000
                  • APNess
                    • 479
                    Originally posted by Doug_RS2
                    Front S2 ARB
                    If you cut it straight.
                    Oops. Cough, shuffle, whistle..
                    'The Bacofoil Express'...
                    No more.
                    Leon TDI 150 run in now.
                    Very slow.
                    Needs a chip.
                    • S2 Ant
                      • 3682
                      Stick to your funnels Paul
                      Ant
                      2011 Kawasaki Z1000
