As title i will be doing all the belts in the next month or so just wondering is there any benefit in fitting the Rs2 water pump and belt.
Rs2 Water pump
The rs2 pump has a 1 less tooth so will probably flow faster, and i think the cambelt is the same so would have to be a tooth out i remember reading about this before, as far as i can remember -
[QUOTE=UrS4boy;692524]Correct. RS2 = 150 teeth, AAN/ABY = 151 teeth
[img]http://12v.org/urs/AAN3BandRS2TimingBelts.
That's what I meant the rs2 belt is the same as the pump a tooth short lolComment
