My wifes 2.6 cabby has failed the MOT on emisssions again.I had no idea it was running so badly,every time I asked her hows the car,see says fine,why o why did I beleave her.
Had this problem last year and changed the lamdas ,cat , injectors ,fuel filter,plugs leads,coil thingy on the balk head,Idle valve. and the oil.
When I drove the car it stalls on startup a couple of times. Its a bit lumpy driving normal,but when you floor it it seems to clear itself and run ok.then when you slow down it starts to run
a little lumpy again.
I dont think see ever drives over 50mph, and that is most likely on **** petrol.
The CO on the failure note for fast idle was 2.13, and at the second fast idle it was 1.25.
At idle it was 1.17.
The car is running rich and you can smell it.So I am wondering what would cause this.Last year I changed the fuel filter and it made a big differance,so I am wondering is it possible that poor fuel delivery from a failing fuel pump or FPR cause a lean mix that makes the ecu over fuel.
I have tried to read the codes with no luck,so I will have to find somwhere that has full vagcome to check it out.Any help in the mean time would be much appreciated.
Ive got a ABC engined coupe with bad emissions.
and I'd use it everyday.
