cam covers
  • audinut
    • Jul 2009
    • 2195
    cam covers
    can an ABY run this cam cover?
    NOT a car dealer! just an S2/RS2 enthusiast
  • djh
    • Jun 2011
    • 1622
    • Home: United States Current: United Kingdom
    yes
    • jsws3
      • Apr 2012
      • 1174
      Yep in fact I have one powder coated red sitting in my garage doing nothing if your interested in it
        That is a modified 7A cam cover, if I remember correctly. Should be possible if you sort out the PCV system ventilation system that involved the ABY cam cover in at least two ways.
        • audinut
          • Jul 2009
          • 2195
          ok so i need to adapt the breather system but otherwise it just bolts on? no difference in length of coils etc
            Nope I think the holes need boring out and milling down a touch. Have a look in Hamish's build thread I'm sure he posted details
            IIRC AndyP has also done this to his 7A cam cover
            • djh
              • Jun 2011
              • 1622
              as alex has said that does need doing.
              • SteveH
                • 4460
                You will need to mill out the spark plug holes and add a takeoff on the cover for the crankcase breather. I used the old breather from my 3B head and moved it over onto the 7A. Angus sorted the milling for me
                91 Modded 3B
                14 A6 Avant Black Edition
                • AndyP
                  • 6049
                  Pics of the mod to fit coil packs
                  • SteveH
                    • 4460
                    Originally posted by AndyP
                    Andy,
                    Is that the Roose RS4 hose for the 3B?
                    When will you be ready to get your car remapped?
                    91 Modded 3B
                    • audinut
                      • Jul 2009
                      • 2195
                      any pics ?
                      I really want to do it as it looks sooo muc better than the aby cover
                      • Pirvu Eugen
                        • Apr 2007
                        • 1978
                        • Country: Romania
                        Hy! It looks strange to me....i installed the coils on top of the 3B cam cover...and they are allmost flush with the cover. The 7A plug wires are longer than the 3B ones...How, in the pictures..the coils are higher from the 7A cover than they look at my engine with 3B cover... Are those fitted right into the plugs?
