can an ABY run this cam cover?
cam covers
That is a modified 7A cam cover, if I remember correctly. Should be possible if you sort out the PCV system ventilation system that involved the ABY cam cover in at least two ways.
Nope I think the holes need boring out and milling down a touch. Have a look in Hamish's build thread I'm sure he posted details
IIRC AndyP has also done this to his 7A cam cover
Imola B6 S4 AvantComment
You will need to mill out the spark plug holes and add a takeoff on the cover for the crankcase breather. I used the old breather from my 3B head and moved it over onto the 7A. Angus sorted the milling for me
91 Modded 3B
14 A6 Avant Black EditionComment
1976 RD250E / 350LC cafe racerComment
Andy,
Is that the Roose RS4 hose for the 3B?
When will you be ready to get your car remapped?91 Modded 3B
any pics ?
I really want to do it as it looks sooo muc better than the aby cover
NOT a car dealer! just an S2/RS2 enthusiastComment
Hy! It looks strange to me....i installed the coils on top of the 3B cam cover...and they are allmost flush with the cover. The 7A plug wires are longer than the 3B ones...How, in the pictures..the coils are higher from the 7A cover than they look at my engine with 3B cover... Are those fitted right into the plugs?
