missfire at 4000rpm
  • crz
    • 7
    missfire at 4000rpm
    Car is a quattro 20valve saloon non turbo the engine code is 7a
    I know that u people mostly have the turbocharged engines but i was hoping maybe someone can help me with a problem so here goes. When accelerating flat out the car pull cleanly up till 4000rpm then it's like there is a rev limiter and it struggles to pull through it, once through it, goes like hell its just around 4000rpm then it clears about 4200 rpm.
    I'm hoping some1 can help me as from what i've been reading u all must be sensor and vacume pipe experts lol! ohhh and it has had a new lambda sensor any ideas , thanks for you suggestions
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    Have you tryed pulling codes from it?
    SS
    • crz
      • 7
      i cant as it is on a g plate and u have to make the flashing light thingie, it doesnt have the dash fault light i think
      is there another way to pull the fault code without home frying the whole wiring harness, cheers.
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Aha. Have you got the 2 connectors?
        Mine look like this.
        SS
        • crz
          • 7
          where? under the dash right hand side or in the engine compartment? i will have a look tomorow afternoon. to be honest im sure i have seen these somewhere so what should i do then.
          cheers
          • crz
            • 7
            actually im sure somebody told me it cant be put on any diag equipment a dealer said a while ago (vag dealer) if this helps
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              It should have them on a 7A.
              They should be just above your right foot.
              If it’s 2 connectors (pre March 1990), get yourself an LED, plug the anode (+) in A2 and the cathode (-) into B1. Turn the ignition on. Then use a jumper wire to connect A1 and B1 for 4 seconds. The LED should then flash out the codes.
              If it’s 3 connectors, same method as above, but the LED cathode should be plugged into B2.
              There’s a guide somewhere on S2Central.net about how to read the codes.
              I normally clear the codes by disconnecting the battery for 30 seconds.
              BTW, make sure you don’t connect A1 and A2 together, what ever you do.
              HTH.
              SS
              • s2avant
                • 2426
                Early 7A engines don't have them. I was stuck with this problem a few weeks back. They do have fault codes but you have you have to use a fuse in the fuel pump relay.
                I can't remember the exact procedure of the top of my head. I'll see what I can find.
                Ben
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  Oh yeah. Just stick the fuse in the top of the fuel pump relay for 4 seconds, to activate the instrument engine warning light.
                  You can activate mine like this too, but I still need the LED to see the codes.
                  SS
                  • crz
                    • 7
                    so stick the fuse in the top of the fuel pump relay to activate the code thing, whilst having the led conected in a2 and b1 under the dash. cheers for the help. will have a go as soon as i see the car again!
                    Communicating with the cpu, what next a cpu that will be able to fix itselfmaybe even order new parts and fit them by itself ,dream on
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      Yep. One of the methods above. Depending on what you find under your dash.
                      SS
                      • crz
                        • 7
                        thanks, j
                        • mcandmar
                          • Apr 2004
                          • 5118
                          Ignore post - Wrong thead - cant delete.
                          91CQ20v - Gone to a new home
                          93UR-S4 - The Magic Carpet
                          94S2Bus - The Emerald Express
