Car is a quattro 20valve saloon non turbo the engine code is 7a
I know that u people mostly have the turbocharged engines but i was hoping maybe someone can help me with a problem so here goes. When accelerating flat out the car pull cleanly up till 4000rpm then it's like there is a rev limiter and it struggles to pull through it, once through it, goes like hell its just around 4000rpm then it clears about 4200 rpm.
I'm hoping some1 can help me as from what i've been reading u all must be sensor and vacume pipe experts lol!
ohhh and it has had a new lambda sensor any ideas , thanks for you suggestions
