hissing/boost problem
  • hermanio
    • Jan 2009
    • 800
    my urs4 developed a problem today.
    under boost i can hear a very loud hissing sound comming from the engine bay/passenger footwell.the car doesnt feel as quick as normal. i dont get a fuel cut under boost.
    what i allready checked:
    - replaced the vacuum/boost hose between the intake manifold and ECU for a new one
    - Did a pressure test and all the hoses seem to hold pressure (all my boost hoses are silicon)
    - checked N75 valve, no leaks- checked hose between n75 and waste gate
    - tested wastegate diagram, seem to hold vacuum
    -checked the one way valve under the intake manifold
    -checked connections at moisture trap.
    -checked the hose inside the ecu.
    also with a pressure test i cant reproduce the sound. Normally with a boost leak you get a fuel cut but i didnt get it this time. Should that mean thats it on the exhaust side ?
    any clues ?
    5 Cylinder Freak
  • Lloyd
    • Apr 2006
    • 1559
    edit, re-read OP. Hmm not sure?
    RS2+ (now sold...)
    • Avantus
      • Sep 2007
      • 941
      • Country: Belgium
      blown mani gasket?
      • hermanio
        • Jan 2009
        • 800
        I think i found it, just checked the exhaust manifold and found 1 loose nut. I tryed to tighten it but i was allready broken. What is the best way to replace the stud ?
        5 Cylinder Freak
          Remove the exhaust manifold, and hope there is enough of the thread sticking out to remove the stud after giving it a good soaking with WD or similar. If that doesnt work likely a head off and off to a machine shop to have it sorted out,
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            That has snapped off inside the head I am afraid. You will either have to take the head off to extract it, or try to drill it out in situ.
            I have done this in the past by making a plate that can be bolted to the exhaust port, with a perpendicular tube attached to hold a drill bit straight, and in position to drill the centre of the offending stud. You will probably need a 90° drill too.
            It looks like the stud has snapped off fairly squarely, which helps.
            When you have drilled a good sized hole into the stud, you can either use a reverse drill bit, or smack a spline or torx bit into the hole to wind the stud out. Use the biggest bit you dare, without drilling the actual head.
            Good luck.
            SS
            • rynaqui
              • Mar 2012
              • 2752
              • Country: Malta
              A risky job though..I think a head off job to be safe..
              1996 S2 ABY Silver
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                Either way it's not an easy job. The head off could be more time consuming, but much easier. If you **** up the in situ job, the head will have to come off anyway.
                SS
