my urs4 developed a problem today.
under boost i can hear a very loud hissing sound comming from the engine bay/passenger footwell.the car doesnt feel as quick as normal. i dont get a fuel cut under boost.
what i allready checked:
- replaced the vacuum/boost hose between the intake manifold and ECU for a new one
- Did a pressure test and all the hoses seem to hold pressure (all my boost hoses are silicon)
- checked N75 valve, no leaks- checked hose between n75 and waste gate
- tested wastegate diagram, seem to hold vacuum
-checked the one way valve under the intake manifold
-checked connections at moisture trap.
-checked the hose inside the ecu.
also with a pressure test i cant reproduce the sound. Normally with a boost leak you get a fuel cut but i didnt get it this time. Should that mean thats it on the exhaust side ?
any clues ?
any clues ?
