Crankshaft toothed pulley - reminder why it's a service item...
  • LHD_Kid
    • May 2006
    • 3697
    Just as a reminder that the toothed pulley is a service item - replace it if you have the slightest doubt...
    I was checking this area due to an oil leak I wanted to cure, thought I would change tha cambelt while I was there, this literally fell apart in my hands - although the woodruf key is perfect....
    be warned...
    Chris
    Jaysus!
    I replaced mine 5 years ago but will be fitting a billet item next time!
    • bilko0795
      • Feb 2011
      • 1883
      Where would i get one of these from in billet.
        034 do them, volcano rs did some one here a while back and I'm sure there are a few others too
        • bartolomeus
          • Jan 2009
          • 1475
          • Country: Romania
          That happened to me as well. I've changed the cambelt waterpump etc and after 1000 km I decided to change the head gasket as well. And I had to work at the cambelt again. Imagine my surprise when I found the toothed pulley broken just like yours and the new cambelt shattered.... Man I was lucky!!!
          I didn't know that it was a service item...
          • simon20vq
            • Dec 2010
            • 1379
            wow I wonder if rust from the bolts or over tightening causes that
              Wrong material choice. It's cracked due to the stress concentration of the holes and the cyclic stress of rotating at an average of about 2k rpm over its life. From teh crystalline structure shown at the crack faces, it's looks to be a brittle material. Error.
              • quattrostyle
                • Oct 2006
                • 6229
                Woodruff key failed on my first S2 and replaced it with one from volcano rs and got a spare for my project engine. Never knew they were about to break like that though
                  I have been collecting photos of failed crank pulleys for years now and that is the first one I have seen that failed that way. It could be a bad batch. All the previous failures that I have seen, it is the integrally-cast woodruff key that fails in some way.
                  How to prevent timing belt and serpentine belt disasters (with DIY links and PNs)
                  • Christophski
                    • 3632
                    On my T4 I had to replace this pulley because when I was doing back up the damper pulley that sat over it, upon tightening one of the little bolts that went into it to a torque of 20nms it snapped clean in half like the first picture.... Luckily i didnt have failure on the move....
                    • bilko0795
                      • Feb 2011
                      • 1883
                      Iv looked on 034 can't find one listed there, Also found Volcano-Rs post on the steel one he had made but that was 2009/10 can't find any later ref to it. wonder if he still makes them?
                        Jesus titty funking christ - lucky escape there Chris!
                        I have spoken to Jamil (volcano rs) a couple of weeks ago about his billet crank sprockets and he can still get them done - I have one on order
                        • bilko0795
                          • Feb 2011
                          • 1883
                          I have spoken to Jamil (volcano rs) a couple of weeks ago about his billet crank sprockets and he can still get them done - I have one on order [/QUOTE]
                          Alex Did jamil say how much the sprocket is.
                          • Costash
                            • 878
                            • Home: Romania Current: United Kingdom
                            I am interested in one of them, can you tell him to make some more please.
                              I will ask him
