Crankshaft toothed pulley - reminder why it's a service item...
  • lagz33
    • Apr 2009
    • 425
    On second thoughts i'm up for a machine cut one
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      #47
      I'm up for one as well..if the price isn't too steep
      1996 S2 ABY Silver
        Originally posted by Pirvu Eugen
        Iff you look closer...the notchwhere the damper comes over the timing belt pulley is flat...soo..either your 4 screws were loose...or the damper was installed wrong to the timing belt pulley..
        There is a "nipple" on the toothed pulley between the (VW) and OOOO markings. There is a dimple in the harmonic damper that fits over the nipple on the toothed pulley. If the dimple/nipple are not lined up, the harmonic damper would put a twist/pull on the toothed pulley as the four allen head bolts are tightened up. Could be the issue.
        Harmonic Damper info: http://forums.quattroworld.com/s4s6/msgs/157639.phtml
        • terrybullwon
          • Mar 2006
          • 8782
          I would have said thats just a marking for the front damper to be on in the correct rotation for the TDC markings on damper
          Chef
          • terrybullwon
            • Mar 2006
            • 8782
            Not that the markings are any good after 20 years
            Chef
              Yes and no. That is so the harmonic damper (which was matched to that crank) is only installed in one particular position so as to maintain the dynamic balance that it was intended to provide due to the inherent non-balance of the inline 5. As it happens, by getting the nipple and dimple lined up, the TDC marking on the edge of the harmonic damper pulley should also be approximately correct.
              Here is the external marking of the damper in action:
              (more cam/crank timing info here:
                Originally posted by andy10v
                What happened to the EFI billet ones?
                I just emailed Marc S. at efi express and alerted him to this thread.
                • pasbogdan
                  • Sep 2009
                  • 1160
                  • Country: Romania
                  #53
                  Things get crazy about those parts.It does not need to be a space ship one,no special extraterestrial material involved.It just have to be in good shape(or new) and all things mounted corectly.Clean bolts,clean surface between damper and it,clean surface between damper and crank to sit perpendicular,good key,corect torques at m8 bolts and crank bolt
                  • quattro84
                    • Mar 2006
                    • 947
                    You are right Bogdan but why risk it failures if an uprated version is available for not a lot more money?
                    It's the same with re-using o-rings and gaskets, if fine it's fine but i don't like hassle if they do start leaking.
                    • pasbogdan
                      • Sep 2009
                      • 1160
                      • Country: Romania
                      #55
                      It is perfect to use a better one,if available.But people get crazy now about replacing them,it is like a disease.
                      • volcano rs
                        • Jun 2005
                        • 2265
                        due to lot of interest for steel crankshaft sprockets i have ordered 10 pieces for now which should be ready sometime next week .
                        whoever wants one pm me .the price is ÂŁ80 including special delivery to mainland uk or ÂŁ85 abroad unless you live on another planet .
                          Nice one Jamil
                          • LHD_Kid
                            • May 2006
                            • 3697
                            #58
                            Originally posted by Error404
                            Nice one Jamil
                            My thoughts exactly..... good man
                            • volcano rs
                              • Jun 2005
                              • 2265
                              4 have been asked for anyone else ?
                              • bilko0795
                                • Feb 2011
                                • 1883
                                Pm sent.
