RS2 starting from cold
  • darreni
    • 68
    • Home: United Kingdom Current: Guernsey
    My Rs sometimes take a couple of tries to start from cold, befor it finally catches.
    Any idea's?
    CAr has a full ASH, & 82,000 miles.
    Darren
  • audiman
    • 4827
    Does it splutter when it does eventually start?? Any smoke from the exhaust?? (black or blue)
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • darreni
      • 68
      No, it's ok. No spluttering & no smoke.
      • DaveS
        • Sep 2003
        • 49
        Is your battery OK ? It could be just turning a bit too slowly in the cold weather, as its low on charge through age or lack of use (like mine)
        I leave mine on a battery conditioner now to keep it topped up and it always starts fine (crossed fingers).
        If it is spinning OK, then it could be an immobilser not disarming?
        Dave
        ex-Ragusa Green RS2
        • audiman
          • 4827
          Check coolant temp sender. The one in the back of the cyl. head. Details are on www.S2central.net IIRC
          Audi UR Quattro
          • Lee
            • 1512
            Hall sender? Mine fails to start sometimes when HOT. I peel back the cambelt cover, pour in some Evian onto the hall sender and it starts!!! yeeehaaa
            Designun Limited....
            • DAVIDP20V
              • Dec 2003
              • 165
              When my hall sender started to fail it was only when hot, but after 3 months of pouring water over it the trick didnt seem to be as effective, even when cold it would refuse to start. Oh yea and mine preferred buxton mineral water from the works water cooler !
              darreni get the fault codes checked if it is hall sender it will register a code like mine did.
              DAVIDP20V - 95' Polar Silver RS2 standard 315 bhp, forge diverter valve, Mark H mod and boost gauge..... and shes for sale.
              • S2sedan
                • Aug 2004
                • 189
                I have the same problem on hot starts, I have to step my foot on the gas. After that, it starts. Hallsender is the same as oxygen sensor ???
                S2 Limo sold !!!
                M5 E34 with some mods in the garage
                sorry, but much happeir now !
                • Lee
                  • 1512
                  Hall sender is camshaft position sender: located behind camshaft pulley on ABY/ADU. Oxygen sensor is different.
                  @David, Sparkling or still?
                  • S2sedan
                    • Aug 2004
                    • 189
                    OPs ... thanks
                    S2 Limo sold !!!
