Yep its down by the ecu Just follow the pipe from the ecu back!
Fault elimination by substitution can be useful if there is a logical reason. If the fault has occured since swapping the ecu's then its either the ecu or its connection to the pipework.
Its unusual but it is possible that the internal hose from the nipple to the map sensor could have split or be detached.
Cars been running awesome for months. Can't remember if it played up before when I had the non chipped ecu or the chipped.
I followed the ecu line it just went through the bulk head and there was no trap ....... unless it's located somewhere else.
Spring looked near new. The diaphragm split free. Ok they all leak slightly.
But if it was failing, be overboosting to silly figures. Never seen my car above what is chipped to.
that´s not true
if your wastegate valve has a lot of play because the long use you will can start boosting like normal..but few seconds later it will pull boost out giving you only mechanicall boost
i happened me with 2 engines... and 2 friends with S2 the same .... so take it in account.
RED Mitsubishi Lancer Evolution VI TME nÂş 16 of 250 BLACK Mitsubishi Lancer Evolution VI TME nÂş 189 of 250
Thing that's good with smoke tester is it located the leak and makes it visual. Can also see if one way valves are working by taking the connecting pipe off. Saves a lot of time searching for split pupes......
Good luck hope you get it sorted.
Audi A6 AEL 5cyl Quattro breaking.
Audi A5 3.0tdi Quattro Stage 2
07947385043
