ABY cam position hall sensor - latest info please
    What's the latest info on these? I'm looking at doing some work on the car and replacing this at the same time strikes me as a good idea. What are the options? I see from this thread that there are a few separate sensors and that Bosch offer the complete part.
    Any info gratefully received
  • bazburn
    • Feb 2010
    • 583
    I have done the replacement 2 ways and both were fine and cheaper than Audi ( depending on how handy you are with a soldering iron and shrink wrap... )
    The latest one I got from Eurocarparts ( Bosch OEM ) and was about 100 squid. Can dig out the part no if you require it...
      Yes please, post it up. I'm happy to solder away, just need to get the part number for the plug and wires.
        Originally posted by Rusty
        What's the latest info on these? I'm looking at doing some work on the car and replacing this at the same time strikes me as a good idea. What are the options? I see from this thread that there are a few separate sensors and that Bosch offer the complete part. Any info gratefully received
        The referenced thread was mine. The update is BB Automacao no longer sells in lots smaller than 100 units. Marc S. at EFI Express has taken up the cause and bought a large lot that he is now retailing at US$10 a piece. I have noted this before.
        G40 Cam Senor info:http://forums.quattroworld.com/s4s6/msgs/22580.phtml
        DIY for replacing the OE sensor with a BB Automacao sender:http://picasaweb.google.com/persing/...orReplacement#
        EFI Motorsport is a company dedicated to providing quality upgrade parts, hardware, software, tuning, and service for a range of European vehicles.
        • johne
          • Apr 2007
          • 1405
          There's also now a couple of UK sellers of the hall sensor who've been noted on here which saves the postage and possible duty on using EFI Express in the US.
          Either way, you'll still need to solder the new sensor into the old loom and need the old bracket.
          John
            Any names or links for UK sellers?
            Are the plugs available to buy separately, so I can solder it all up beforehand? I seem to remember plug suppliers being discussed a while back, anyone remember the company?
            Finally, does anyone have a knackered old sensor kicking about that they don't need the bracket off? Be good to get it all ready.
              ...Are the plugs available to buy separately, so I can solder it all up beforehand? I seem to remember plug suppliers being discussed a while back, anyone remember the company?.
              If you look at the G40 info link I provided above and read down, you will find the PNs for both the female and male 3 pin connectors that you might need. Used VW/Audi 3 Pin O2 sensor connectors also work (potted pins but you have to splice anyway).
                Great stuff, cheers.
                • V6quattro
                  • Sep 2008
                  • 949
                  Fitted a Bosch one to my car some months ago. Was around 120euro i believe.
                  The Bosch G40 is just a original Audi part only the Audi logo was grind off
                  • rynaqui
                    • Mar 2012
                    • 2752
                    • Country: Malta
                    I may have to take the plunge sometime and get an original Bosch item, definitely DO NOT want my car to stop on the side of the road
                    1996 S2 ABY Silver
                    • bazburn
                      • Feb 2010
                      • 583
                      Part no is 419440650 and they call it an ignition pulse sensor. HTH
                        No offense but that Part No. doesn't seem to be valid. The G40 is called a "cam position sensor (hall sensor)" not an impulse sender. See Item 10, PN 034905161, below (Same for AAN, ABY and ADU).
                        • bilko0795
                          • Feb 2011
                          • 1883
                          Any update on where to source this sensor from in the Uk.
                          • johne
                            • Apr 2007
                            • 1405
                            These were the two I was thinking of from an earlier post:
                            and
                            http://www.ebay.co.uk/itm/1209502076...84.m1423.l2649
                            The eBay one is actually from the US even though on eBay.co.uk and Marc at EFI Express would be a better bet.
                            John
                              John
                              Based on what I read at http://www.jaycarelectronics.co.uk, the one they have on offer is very likely to be the same one BB AutoMacao and EFI Express have except jaycarelectronics have them in the UK.
                              Dave F.
