Nylon-plastic fuel lines
  • george21
    • Aug 2007
    • 226
    • Home: Lithuania Current: United Kingdom
    I'm looking to replace all fuel lines on my ur quattro. And looking for alternative to oem as they n/a and come across of plastic/nylon fuel lines. Question is: are they safe to use it? And where, which ones to buy it. Thank for advice!
  • jsws3
    • Apr 2012
    • 1174
    Ptfe braided lines are the way to go as that's what I'm doing with mine on my ur .
    • andy10v
      • 5996
      If its the hardlines under the car I would use the cupro nickel/cunifer stuff. Easy to shape by hand, does not rust, and does not break the bank either. Cost me less than £50 to do the full lines on my s2 including fittings and have spare.
      Sold ABY-stock
      • Tonks4x4
        • Nov 2005
        • 3062
        I have used all the versions now and my preference for future installs is to use PTFE lined braided hose
        Audi Nut!!!
        • 5cylinderman
          • Oct 2011
          • 367
          Nylon fuel lines
          The only problem with using non-metal fuel lines is in the event of a crash.
          With metal lines if a line gets fractured in the engine bay after a collision much less fuel will be spilled (once the pump cuts out).
          With plastic, if there is a fire in the engine bay the nylon hoses will melt and a lot of extra fuel will be introduced. If the line burns down to fuel tank level the fuel will flow from the tank towards the engine bay and result is catastrophe. Food for thought.
          • martinws
            • Oct 2008
            • 917
            I have read that when using braided lines you should get them with a cover over the stainless braid as grit can get into the weave and wear through the PTFE inside. I cannot back this up though as i dont remember where i read it. I think it was in an argument as to why HEL hoses are really good with the cover over them.
            • 5cylinderman
              • Oct 2011
              • 367
              On the rally cars that I have been involved in preparing over the years we use cupro nickel tubing fitted with small fire traps at the engine bay and at the fuel tank. IF there's a fire at either end it minimises it travelling. Most importantly to give us time to get out of the car, but also to try to save the car. This was brought on when our esteemed leaders in Motorsport Ireland decided that we must only use AFFF in our fire extinguishers. This stuff is not good at putting out fires, so we took further measures for protection.
