How many have used SUPERTECH pistons.
Managed to get a set from Rosten performance before website and Geir Rosten vanished
The spec sheet says that the minimum clearance for these pistons is 0.07mm and have had mine set to 0.075mm, some are saying it should have been 0.085, but as supertech use an alloy with 18% less expansion than the likes of JE i should be OK but be interested to know what others using supertech have used. Cheers
. The spec sheet says that the minimum clearance for these pistons is 0.07mm and have had mine set to 0.075mm, some are saying it should have been 0.085, but as supertech use an alloy with 18% less expansion than the likes of JE i should be OK but be interested to know what others using supertech have used. Cheers
