Engine Rebuild Cost?
Seems that I'm thinking along the right lines. A lot of the bolt on stuff is already there, it's the internals that are of concern. Just have to piece together some pennies now and then I can get this sorted.Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
Defo getting up there on the money stakes but still less than 7k as a stroker designed to bounce of a limiter harder than a 2.2. Add a dry sump and yes you'll easily surpass 7k if going all out.UrS6 Stroker + HTA3586 =
So, from reading the comments, I'm happy that my assumptions were along the right lines:- Rebuild with rods, clutch and basic head rebuild ~ ÂŁ2000
- Ported head ~+ÂŁ500
- Re-bore & new pistons ~+ÂŁ750
Haha doubt it hmmmm you will be getting a pm!
