Engine Rebuild Cost?
  • campbellWS
    • Oct 2010
    • 446
    Originally posted by Rocco
    7000 pounds for only engine block?
    7k seems fair for one bad *** bottom end if you want to go all out, if someone wanted to replicate JP's bugswatter bottom end i think it would be much more than that. all depends on persons power aim, budget and engine "bombproofness"
      Seems that I'm thinking along the right lines. A lot of the bolt on stuff is already there, it's the internals that are of concern. Just have to piece together some pennies now and then I can get this sorted.
      • JP
        • 1858
        Defo getting up there on the money stakes but still less than 7k as a stroker designed to bounce of a limiter harder than a 2.2. Add a dry sump and yes you'll easily surpass 7k if going all out.
        UrS6 Stroker + HTA3586 =
        • campbellWS
          • Oct 2010
          • 446
          Taking all your labour into accountHaha doubt it hmmmm you will be getting a pm!
            So, from reading the comments, I'm happy that my assumptions were along the right lines:
            • Rebuild with rods, clutch and basic head rebuild ~ ÂŁ2000
            • Ported head ~+ÂŁ500
            • Re-bore & new pistons ~+ÂŁ750
            • Sonic
              • Jul 2006
              • 5514
              #36
              Another thing i found out is sometimes you just dont know what you'll find or what needs doing/replacing until you open it up...
              S2Forum.com Administrator
                Yes, that's another worry.
                Could go 2.3 ghetto build, like this post
                  I would just budget to do it once and do it right first time
                  • Sonic
                    • Jul 2006
                    • 5514
                    #39
                    Can still come back and bite you
                    (Not to put you off Andy )
                      I've been doing this long enough to know the pitfalls
