what rods do i need ?
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    Originally posted by Pat D
    I agree, the rods look great. I have an exhaust manifold + 4inch downpipe made by Hank. If you're after quality I would def consider one, and he's always really helpful if you need any advice.
    so did he build that custom downpipe for your setup because you will use his manifold true? ...interesting... because i will need a bigger downpipe if i can
    • Thuppu
      • 4115
      Tomas, nothing is enough for you.
      BTW, really nice loocking manifold and DP.
      • Pat D
        • Dec 2011
        • 748
        • Country: Australia
        He sure did, the work is superb. The welding is the best I've come across. Send him an email, I'm sure he'll be happy to do whatever work you need done
        ABY S2 stroker (work in progress)
        B5 1.8T quattro
        B4 2.3 (decommissioned)
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          Got a gtx3582 ready to tune ....and full 3" turbo back... I bet your exhaust system is better than mine
          And that's my last power upgrade ,so there are.limits
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            #20
            We are in contact dealing with a wastegate....
            Thanks for.your feedback!
            • |CL|NIKI
              • Jun 2008
              • 380
              • Home: Bulgaria Current: United Kingdom
              #21
              The GT 3076r with .82a/r I enough for up to 550hp. And will push hard from 3800 to 6800 at 2bar. You don't need so big down pipe- 3" are enough for this hp even fore more.
              800HP 800++Nm
              • |CL|NIKI
                • Jun 2008
                • 380
                #22
                Tomas, the 3" dp is enough for even 800 hp that are absolutely dream for this teen turbo
                800HP 800++Nm
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  #23
                  Got now a gtx3582..82ar and.I'm going to map.it with 98 octane fuel and aquamist hfs3...
                  Good to hear!
                  Anyway I'm fitting a cutout exhaust valve just where downpipe ends... To help with back pressure! I'm sure it must help a little
                  Edit .and I run a separate screamer pipe
                  • URQguy
                    • Sep 2008
                    • 245
                    We have seen over 700whp on the gtx3582r on e85. With extended tip, it is almost a 86mm exducer turbo. It means business. This "teen" turbo has put Evos into the low 9's here in the USA.
                    1981 URQuattro with the TIAL GT35r.
                    2007 Infinity g35
                    • drego786
                      • Feb 2013
                      • 27
                      lovely looking piece of kit
                      • |CL|NIKI
                        • Jun 2008
                        • 380
                        #26
                        Me advice (GT3076r) was to micky, not to Rocco.Than just told Tomas that He dont need 4" DP for 35 turbo even GTX.
                        And Yes - single GTX35 on a stroker engine with 1.01 a/r or even 1,15 a/r + 100% methanol can push 800 engine hp (maybe)..
                        It can put Evo's that are under 1000kg in 9 sec, with more than 40psi boost and E85 fuel + Dog gears and sequential shifter...right?
                        Here We have stroker that produce 730hp at 30psi with HTA3586 1 a/r, 100 octane normal fuel, no water/methanol - it is in middle 9 sec.
                        800HP 800++Nm
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          #27
                          100 octane is normal fuel in yor country?
                          here unfortunately 98 is the maximun available
                          the same turbo will make more power in a stroker than in a 2.2? or the same but with less lag?
                          • |CL|NIKI
                            • Jun 2008
                            • 380
                            #28
                            More power and early boost. Our 100 octane maybe in fact, is not more than 98 really. Normal fuel here is 95, but for racing cars all We use 98 or 100. Thats why 100oct is normal for racing guys with over than 300+ hp. We dont use E85 because We dont got it here...
                            800HP 800++Nm
                            • caterpillar
                              • 2480
                              #29
                              Dp
                              tryed the difference between the 3" and 3,5 or 4".... and all the way back think you should give it a try...
                              even old diesels became unbelivabel... with 500000km at the meter...
                              • caterpillar
                                • 2480
                                #30
                                sorry; little OT......
