There are no problem running any power output with Motronic.
The only limit is knowledge of the ECU.
Safer and more efficient without knock control? Again, you are wrong here.
I will always do that, because Bosch has been 20 years ahead of it's time.
Motronic 2.3.2 is better than most standalones in 2010, and it was developed in 1990.
Motronic 7 is still better than ANY other ecu apart from newer Bosch ones and it was developed in 1997. Nothing comes even close in the world. And we are in 2013, so 16 years later.
Again you are wrong. In fact Motronic has about ten times the possibilities of any standalone ECU for fuel and spark tuning. And ME7 100 times more possibilities.
And again you are wrong. Completely wrong.
I can live tune the car on the road and I have full data logging from the ECU.
Better troubleshooting? I don't think so! Motronic has full self diagnosis, your ECU does not have a fault code system.
As for processing power - M2.3.2 has four processors. Maybe something to think about.
Basically - you have no idea what you are talking about.
You don't know how an ECU works inside. All your cr*p about "more precise, better" is just marketing.
If you knew how ANY ECU works inside, you would realize how ridiculous your claims are.
High end stand alone ECUs are made to work with them easy as possible and produce power safer and efficient as possible.
however please don't compare 25 years old technology with something from recent days.
Precision is matter of tune and configuration and those ecus gave you so much more layers for precise tuning
and extra features which makes engine better and safer to run.
Not on last place live tune, making changes at any time, better troubleshooting, literally you can tune on the road road.....
