thermo tec heat sleeve
Tags: None
1994 ABY Coupe - Projekt AlpinweissComment
We made a load of shields for my mates R32 turbo out of this stuff
Good quality and nice to work with, very similar to the modern stuff VAG is using now.Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
in my case it'll be veggiefoil....
cheers for the tips guys....I'm not sure of where to fix it to the body hence why I thought that surrounding the connector would be the best option....I might have a look at extending the stock heat sheild that sits behind the DP....Comment
You could either
Get some Raychem and shrink it onto the cable this will give you up to something like 150 degs
Or run a rear sensor in the front with the longer cable?ChefComment
stupid question time, surely if the connector joins above the DP it wouldn't matter whether it was the long cable or not....
I have some rear coupe ones in a box some where. If you can measure the length of the front one you have and if it turns out to be shorter.
Your welcome to what i have hereChefComment
