ABY Timing belt/water pump woes.
  • re2500
    • May 2007
    • 2185
    Ive been collecting parts over the past few years in preparation for a timing belt renewal on my ABY.
    I decided to go ADU belt and pump, just because...
    I bought the pump first from a forum member and was sure i had the correct one based on this:
    I confirmed the PN via PM before purchase and counted the teeth and checked PN when it arrived:
    PN: 034 121 004A on box, pump has 29teeth.
    IN the mean time i aquired a roller, crank bolt and sprocket (all common to ABY and ADU so no prob) but also sourced a RS2 belt.
    But i have since found out that 29 teeth is not an RS2 pump
    Can anyone confirm what pump i have?
    If its an ABY pump then should i buy another pump for an ADU or another Belt for an ABY
    thanks in advance for any help.
    Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
    "Difficult is worth doing"
  • re2500
    • May 2007
    • 2185
    Just had another thought, it is possible that he PN on the pump box does not correspond to the pump in the box? Wouldnt be the first time....
    • re2500
      • May 2007
      • 2185
      Anyone know what pump this is?
      • Laaf
        • Oct 2010
        • 275
        There's a picture of a ADU waterpump, the sprocket has got 4 holes in it and 26 teeth. The housing part number is 074 121 019C which is a 5-cyl TDI number.
        • twoqu
          • Sep 2003
          • 3103
          According to this it sounds like a 3b pump.
          A pic would have helped to ID it. Does it have three bolts holes or are two of them slotted? If its slotted its not an ABY/RS2 fitment.
          • re2500
            • May 2007
            • 2185
            Cheers guys, it does have slots, so sounds to me like i have a 3B, 7A etc waterpump.
            Time to find a decent quality and reasonably priced ADU pump...
            • Laaf
              • Oct 2010
              • 275
              The ADU waterpump would have cost me 399€ from Germany, and they are available through Audi only. I went for a AAN pump and belt. Also the guy I buy parts from stated the ADU timing belt was the last one in Germany
