Ive been collecting parts over the past few years in preparation for a timing belt renewal on my ABY.
I decided to go ADU belt and pump, just because...
I bought the pump first from a forum member and was sure i had the correct one based on this:
I confirmed the PN via PM before purchase and counted the teeth and checked PN when it arrived:
PN: 034 121 004A on box, pump has 29teeth.
IN the mean time i aquired a roller, crank bolt and sprocket (all common to ABY and ADU so no prob) but also sourced a RS2 belt.
But i have since found out that 29 teeth is not an RS2 pump
Can anyone confirm what pump i have?
If its an ABY pump then should i buy another pump for an ADU or another Belt for an ABY
thanks in advance for any help.
