Fitting new lifters / tappets
I've replaced all 20, but whoever had the engine before me seems to have possibly removed one of the old ones with a screwdriver, I can see hints of damage at the top of the tappet bores and that one tappet doesn't like turning once installed, the rest all turn freely.
I'm probably going to regret asking the question, but can you get the tappet bores honed/machined and does anyone know a machine shop I Can trust y head with?Comment
You can remove any local high spots caused by the previous owner with some fine wet and dry, obviously making sure you clean the head well after to remove any abrasive. I don't think you can get oversized lifters and if you got some from another motor, you would have to ensure the total height was spot on. Probably best just to fix the localised damage.91 Modded 3B
14 A6 Avant Black EditionComment
Yes, there is 0,5mm oversize lifters available from INA(420004010), but the price totally freaking absurd. When you can get stock size for under 4e/piece, these are 30e/piece. One small scratch in the lifter bore won't do anything. Just smooth it out little bit if the lifter sticks.
BMW 740iA e38 - ProjectComment
I turned the engine over by hand first to make sure nothing was hitting and then fired it up. The oil needs to heat up before they shut up, so as above, 15 mins on idle just about does it.Cheers'en, AndyC
Cool, thanks for the responses.
I've rebuilt and run it up for 5 minutes but because of that sticky tappet I've ordered a few spares and I'll replace it and clean the bore before I try again.
Looking at possibly head off for a clean up and polish of the camshaft, but I'll add that to my own thread if I get onto that!Comment
While I'm here and I have your attention I may as well ask another question (2 actually) and they are related...
1) When removing just the inlet camshaft is it normal to have to remove the stud for the end cap to enable the lifting out of the cam (New chain so extra tight)
2) Why can't I get the two spots on the inside of the cam wheels to line up exactly, or rather I can, but then the camshaft aligning dot for the timing belt is misaligned. Does anyone have photos of their correctly aligned non vernier camshafts ?
TaComment
Yes, the intake cam won't come out if the stud is not removed. Perfectly normal.
The timing spots are little bit off with stock cam gears. In fact the crank mark is a little bit off if you measure the real TDC. But of course you will be able to set it on the closest tooths with the stock markings.
Ta
Confirming. Couldn't align mine perfectly as well. Off by approx half a tooth.
Sent from my iPhone using TapatalkComment
I'm also looking at replacing tappets. My new INA ones with around 3, 000 miles are rattling badly on 2 cylindets.
Having spent hours looking into this, am I right in saying that ALL new type lifters do not have the large oiling hole in them... meaning it doesn't really make any difference what you get? OEM INA, although still not great, are as good as you can buy?Honda CBR 1100XX Blackbird Turbo....undergoing major changes.....
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
