Where do these hoses go?
  • Colesy
    • Feb 2009
    • 2981
    Have had the S2 in pieces and thought I'd fit the Samcos I had in the cudboard while I was at it. But can't work out exactly where these four hoses are supposed to go?
    One has some sort of bleed valve on it, a few pics should help:
    I realise I'm probably just blind!
  • GazzaG60
    • 4133
    one with screw I presume for the heater matrix bleed.
    other one for other side of matrix I think.
    2 little straights look like "oh spares" "ill keep those in cases" hoses ??
    • andyg plym
      • Nov 2006
      • 4646
      dont forget the small hoses tucked underneath out of sight, ie thermostat housing and theres one above it tucked right under the inlet manifold
      • mcandmar
        • Apr 2004
        • 5118
        As above engine to heater matrix, as for the other two i think they are for the engine block coolant rails, trim to fit basically.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • LHD_Kid
          • May 2006
          • 3696
          agreed, but the 2 straight are the ones tucked up under the IM...
          • John B
            • Apr 2008
            • 926
            2 x heater matrix and 2 for under water rail (little b**gers they are too!)
            Have a look at http://www.s2forum.com/forum/showpos...0&postcount=23
            2001 996 C4 - Being renovated
            1994 ABY Coupe - "Das Smaragd RS2+ Coupe" - Sold
              The fatter of the two straights connects the thermosat housing to the steel water pipe that runs round the back of the block.
              I am sure the thinner of the two connects the turbo coolant line that runs round the front the block to the water rail banjo.
              • GazzaG60
                • 4133
                if like me they don't fit on the car but hang very nicely in a bag in the shed for over 2 years.
                • Colesy
                  • Feb 2009
                  • 2981
                  Great, cheers guys.
                    Agree, as shown here on an AAN (similar for ABY and ADU etc):
                    • benntenn67
                      • Jun 2009
                      • 859
                      The bendy one without bleed nipple - isn't that the rad to header tank one ??
                      Audi S2 Coupe 1995
                      VW Passat GL5 (hatch) 1986
                      Carrera Subway 8
