Compression test results...
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    Originally posted by caterpillar
    have some oil in,, se if its the ringland or the walve.... komp will raise big numbers.. the piston or rings are gone,, will raise low mumbers.. the walves
    Oil will raise any numbers big or low if rings/bores are gone.
    Oil will not raise any numbers(low or big)if valves are leaking.
    This engines use to wear bores more than rings.But i guess a valve problem is your problem.I explained some time ago that 0.3mm bore wear resulted 10-to 12 bar comp at hot.So compresion test will not prove rings or bores.It will prove more valve wear.
    I am also sure that bore wear will be more than 0.03-0.05mm.So be prep to overbore if you open engine and rebuild head/leaking valves.Also change valve guides.
