Since I put the pics on my build thread I've had quite a few PM's asking exactley what I had to machine to make the coilpacks fit the 7A cam cover, so I thought I'd put all the info in one thread.
First of all there are two types of coil pack, long and short. Not sure which ones these are but these are mine
To make them fit I had to trim one of the sealing rings off and trim down the stop. This is before
And after. The alternative to this would be to machine a notch in the side of the raised ridge on the cam cover. Hamish did it this way on his cover
The cam cover as then bored out to a hair under 31mm dia and 15mm deep.
Coilpack fitted
Coilpack fitted
