DIY Cambelt / Timing Belt Change???
  • Fat Audi 80
    • 10547
    Originally posted by johne
    Steve, equally, happy to help.
    I've done my belt twice and each time I locked the crank by removing the flywheel tooth counting sensor and locked the flywheel ring gear. I know the purists won't agree with me but it's worked fine so far.
    Agree that you need the 3/4 socket and bar to undo the crank bolt although then again I've managed twice with a 1/2 inch one and one breakage I now have a 3/4 one waiting for the next time.......
    I would recommend changing the waterpump at the same time given that it's not expensive - well at least a GSF or ECP patten part isn't, which is what I've used with no problems.
    John
    Same again, thanks John I appreciate the offer.
    I would like to do it one weekend in April, preferably before the 26th as I don't fancy doing it over my birthday weekend!
    I will let you know.
    Cheers,
    Steve
    The Perfectionist
    • Fat Audi 80
      • 10547
      Help! Tools and parts have arrived, but I no longer have a crank locking tool. Can anyone lend me one please? I am happy to pay postage and return it ASAP...
      Steve
      The Perfectionist
      • merlin's S4
        • Jan 2005
        • 1539
        I've got one! Think ABY and AAN are the same. 3256 iirc. Feel free to send a pm if you're still stuck.
        • merlin's S4
          • Jan 2005
          • 1539
          Originally posted by K Simmonds
          It should do the job just fine but you'll probably have to wedge it against the floor or the the stub mount as opposed to it locking nicely on TDC like with the correct tool.
          Just for reference the 3256 tool doesn't lock at TDC. Don't ask me why!!
          • Fat Audi 80
            • 10547
            You have PM!
            The Perfectionist
            • Fat Audi 80
              • 10547
              Update:
              If you ignore my posts regarding the problems bleeding the cooling system, this has been a success! Cambelt, tension roller, water pump were all changed without too many problems.
              I should add for completeness that the 3256 tool does not fit the ABY without modification. I have covered the details of the modification here: http://www.s2forum.com/forum/showthread.php?t=5042
              Basically, you need a length of M10 studding and some washer / nuts as spacers in order to bolt the locking tool to the block....
              I will be providing these with the tool when I send it back so that others don't have to run down to their local B&Q
              Cheers,
              Steve
              The Perfectionist
              • audinut
                • Jul 2009
                • 2195
                just did mine - got the 200nm fine but wasnt overly confident i got a true 180 degrees ..... 3/4 bar and extension and i was hanging off it ...
                NOT a car dealer! just an S2/RS2 enthusiast
                • rj scotty
                  • May 2006
                  • 2195
                  #23
                  I bet you where close enough
                  BUT I DON'T WANT A NEW CAR!
                  1995 S2 Avant, Volcano Black
                  • Fat Audi 80
                    • 10547
                    Yeah, I only managed 100 degrees after 200Nm, hanging off a 1m 3/4" breaker bar, but then I am a lightweight 70kg
                    The Perfectionist
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      #25
                      Blimey Steve. You're as heavy as that? Either you've put on weight since I last saw you, or I need to get down the pie shop!
                      By my reckoning. If you stand on the bar when it's horizontal, 655mm from the centre bolt, that should get you 450Nm.
                      I have to use the full metre bar with Steph, aka my special tool.
                      SS
                      • re2500
                        • May 2007
                        • 2185
                        Yeah that final 180deg is a pain! I think Kit and i managed about 160-170 deg. That was with Kit bouncing up and down on his bendy 3/4" breaker bar.
                        TBH i think 180deg is a bit overkill. Im sure 100deg will be fine, the bolt will be stretched nicely.
                        "Difficult is worth doing"
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          #27
                          This is why I rarely use a torque wrench. Tightening things by feel is a much better idea, as long as you have experience of what feels right, and what feels wrong. But I recommend getting a feel for what feels wrong on less important stuff.
                          SS
                          • re2500
                            • May 2007
                            • 2185
                            • Fat Audi 80
                              • 10547
                              Yeah, I'm 70kgs on a good day, 66 if i am feeling light!
                              i am happy with the torque achieved on my crank bolt.
                              incidentally, i am now down on Somerset and the S2 had made the trip in heavy traffic no problem. i am very happy with the car again....
                              The Perfectionist
                              • 4WheelDrifter
                                • Oct 2004
                                • 5773
                                • Country: Devon
                                #30
                                About the same as me then.
                                If you were hanging off of the end of a metre long bar, then I would make that a force of ~686Nm, depending on tide times and so on.
                                So I would think it's tight enough.
                                It's good to know it's all test driven and checked.
                                Incidentally I am up in Somerset too. Making use of proper internet availability.
                                SS
