1.8 turbo wont start , no spark on coils neither fuel pumps works help please
  • kninio
    • Aug 2004
    • 641
    • Home: Lebanon Current: United States
    Hi to all ,
    it had broken alternator belt , and next day after changing it , it cranks but fuel pump doesnt works neither the coils getting electric , so no spark and no fuel to the injectors any idea why is this? i havent vag com to scan it at the moment could it be some sensor that disable both of those items? any help would be appreciated.
  • Val
    • Apr 2008
    • 630
    • Country: Latvia
    What have you checked by now? Fuses?
    5vtq gte
    • kninio
      • Aug 2004
      • 641
      fuses all ok relay all ok , i tried to start the fuel pump directly , but didnt start up i took of a coil and spark plug and there is no sparking , so two things is not working fuel pump and ignition coil system , what could disable both of those? , my stupid mind make me forget the vag com at home while the car is in the village so i couldnt scan it
      • sam80quattro
        • Oct 2006
        • 1496
        no power to ecu? pump should prime off the key.
        • kninio
          • Aug 2004
          • 641
          pump is not working for few seconds netheir while cranking , no ignition spark either, how cani check power to ecu?
          • ManiacuV6
            • Dec 2009
            • 458
            • Country: Romania
            I put my money on a Immobiliser problem. It can be repaired. OR you can get another IMMO box with a pair transpoder and adapt it to the ECU.
            Audi S4 2.2T 5 spd 1992 for parts
            AUDI A4 1.9TDI daily use
            Audi 80 Quattro 2.0 16V (ACE) aka Competition
            • A1QSHIP
              • Aug 2004
              • 975
              May just need to reset the IMMO. Try locking & then unlocking at the door or with the remote & then immediately try to start.
              Good Luck, Chris
              "Nulla tenaci invia est via"
              • Monkeymagic
                • Mar 2012
                • 3419
                what car are you working on.
                • kninio
                  • Aug 2004
                  • 641
                  audi tt 2000 , without imobiliser its a us one they didnt have imobiliser untill 2003 , but the issue its not starting and shuting like when the immo block it , it doesnt start at all just crank with no pump or sparks
                  • Val
                    • Apr 2008
                    • 630
                    • Country: Latvia
                    Do you have +12v on coils and injectors while cranking?
                    Please, delete posts mentioning immobiliser. Its not how it works.
                    5vtq gte
                    • sam80quattro
                      • Oct 2006
                      • 1496
                      when immo gives you problems on 1.8t they still start buy then cut out.. get a multi meter and test the power wire to the ecu. you'll need a pinout diagram ideally so you know what's what but there easy to find online
                      • sam80quattro
                        • Oct 2006
                        • 1496
                        i recently fixed a mates golf that had a cracked scuttle panel.. ecu was full of water. worth checking
                        • kninio
                          • Aug 2004
                          • 641
                          it doesnt start and shut at all , just crank with no 12v+ to pump neither to coils , i will take the vag com and go check it and update you with the results , maybe ecu dead as u said possible water got on it
                          • Val
                            • Apr 2008
                            • 630
                            • Country: Latvia
                            delete this.
                            5vtq gte
                            • kninio
                              • Aug 2004
                              • 641
                              Originally posted by Val
                              Which one engine code your car has?
                              its ATC , equal to AUQ euro one
                              thanks for the BAM data its usefull for my s3
