1.8 turbo wont start , no spark on coils neither fuel pumps works help please
Don't do that . Don't put an ECU if you don\t know that the pinout is the same.
IS hard to do that but : KEEP CALM and check the supply first !Audi S4 2.2T 5 spd 1992 for parts
AUDI A4 1.9TDI daily use
Audi 80 Quattro 2.0 16V (ACE) aka CompetitionComment
i will
, even the bam have difference plastic driveway to prevent it fit in difference plugs , i will check supplys cos i am sure something is not functioning , the car had cuted alternator belt and continue working untill home , and since then didnt start anymore.
only thing that i can think would do that is broken earth strap.
or alternator over charged. see if the clutch pulley is still working. i think they have them on 1.8t just like a diesel.Comment
You said you "charged it".
With a charger I guess? Well then probably the charger was crap and overvolted your ECU, thus it fried - easy peasy.Comment
the car was with a relative and he told me alternator belt cut off and he drive it till home , and turn it off normaly , when i come to pick it up the battery was strong but didnt turn on , he claim it was ok , so maybe he recharged the battery and put it in the car back.
clutch pulley is ok i inspected it.Comment
Prj : its not my fault but no one admit how it become like that. i would charge the battery outside then fit it back. i inspected +V with ignition on and +v permanent and both earth all works , then i put the 225 ecu and EPC light came on and car started for 3 seconds and then blocked by immo , so i become sure that the ecu is killed.
the car had faulty coolant fan controler , and the battery was drained one week a go and they boosted it to start could it be the reason?Comment
thanks for everyone
