1.8 turbo wont start , no spark on coils neither fuel pumps works help please
  • kninio
    • Aug 2004
    • 641
    • Home: Lebanon Current: United States
    #31
    Originally posted by ManiacuV6
    THe witing harness for 1.8 T is fairly the same on cars with drive by wire throttle . So you won't do anything wrong. USe the AUQ wiring from Autodata. Good luck!
    i will do that, i tried to plug in ecu from tt 225 , but didnt fit they have some difference drive ways to prevent using it in difference car i dont know why , i just wanted to see if vag com will see it.
    • ManiacuV6
      • Dec 2009
      • 458
      • Country: Romania
      #32
      Don't do that . Don't put an ECU if you don\t know that the pinout is the same.
      IS hard to do that but : KEEP CALM and check the supply first !
      Audi S4 2.2T 5 spd 1992 for parts
      AUDI A4 1.9TDI daily use
      Audi 80 Quattro 2.0 16V (ACE) aka Competition
      • kninio
        • Aug 2004
        • 641
        #33
        i will , even the bam have difference plastic driveway to prevent it fit in difference plugs , i will check supplys cos i am sure something is not functioning , the car had cuted alternator belt and continue working untill home , and since then didnt start anymore.
        • kninio
          • Aug 2004
          • 641
          #34
          it turned out to be dead ecu , what could kill it just like that? could a broken alternator belt cos this? i turned it on with 225 ecu and connected vag com too.
          if i got ecu with imo , how can i disable it?
          • Monkeymagic
            • Mar 2012
            • 3419
            only thing that i can think would do that is broken earth strap.
            or alternator over charged. see if the clutch pulley is still working. i think they have them on 1.8t just like a diesel.
            • prj
              • Mar 2010
              • 6308
              You said you "charged it".
              With a charger I guess? Well then probably the charger was crap and overvolted your ECU, thus it fried - easy peasy.
              • kninio
                • Aug 2004
                • 641
                #37
                the car was with a relative and he told me alternator belt cut off and he drive it till home , and turn it off normaly , when i come to pick it up the battery was strong but didnt turn on , he claim it was ok , so maybe he recharged the battery and put it in the car back.
                clutch pulley is ok i inspected it.
                • kninio
                  • Aug 2004
                  • 641
                  #38
                  Prj : its not my fault but no one admit how it become like that. i would charge the battery outside then fit it back. i inspected +V with ignition on and +v permanent and both earth all works , then i put the 225 ecu and EPC light came on and car started for 3 seconds and then blocked by immo , so i become sure that the ecu is killed.
                  the car had faulty coolant fan controler , and the battery was drained one week a go and they boosted it to start could it be the reason?
                  • kninio
                    • Aug 2004
                    • 641
                    #39
                    solved , i boughet ecu with same part number and it works fine thanks for everyone
