I have just completed a 20v turbo conversion for a friend and the car will not boost past 0.5 bar.
I have sofar replaced the DV, Boost leak test (OK), VAGCOM (no codes) and checked all fuses plugs ect.
I am assuming the N75 is not getting a signal from the ecu to change state, there is 12v at the plug when the car is running but it doesnt change state when the throttle is opened.
Which sort of explains the 0.5 bar as it will bypass straight to the lower chamber of the wastegate.
Will the ecu stop the N75 if there are problems elsewhere? im pretty stuck with this really as mentioned before there are no fault codes....??
