hello,
my audi s2 3b has some boost problems..i was using a chiped ECU but it got bost cut and if i acelerated from 3rd gear (flored it) it was jumping violently... so i changed the ECU to the standard.. the prob if violent jumping was gone...
but it only boost up to 0.5 bar and no problems in vagcom... today i changed the n75 valve to test it and it overboosted to 1.1bar and vagcom it showed 0544 boost to high and was jumping violently on standard ECU..
do you have some advice so i can enjoy my s2 again???
