no prob i got time.. and in my city no one can do a leek test... no audi or vw center does that... so the best thing would be to have this tool for myself... the hoses are not geting newer with the time..
today cleand maf and other contacts but no use... stil 0,5-0,6 bar...
...today cleand maf and other contacts but no use... stil 0,5-0,6 bar...
Boost leak testing is something that you can do yourself (maybe with the help of a friend with a compressor).
As for the 0.5 to 0.6 Bar boost, that is just wastegate spring-based mechanic boost pressure which sounds suspiciously like the ECU is not getting the boost pressure signal at the MAP sensor in the ECU and therefore is not controlling the wastegate frequency valve. My suggestion is to check the lime green plastic line from the back of the intake manifold to the ECU. In addition, there is likely a "T" near the intake manifold and if it is broken, you might not be getting the proper pressure/vacuum at the fuel pressure regulator.
today i was at audi... and wanted to buy a few parst for my s2... and asked what would a hose from n75 to wastgate would cost... WTF??? 70euros.... cant believe it myself ...
today sprayed all the contacts with contact cleaner, changed the n75 to a new one, changed the moisture trap and yeaehhhhh got 0,7 bar boost with standard ecu and with chiped one 0,9 bar boost... i think there is a boost leek somethere thow..
today is my wifes birthday but why im geting all the present????
and special thanks to forum member bartolomeus its always a pleasure doing business with u
