Coolant warning light?
  • Rikki Kitto
    • Feb 2010
    • 6276
    OK just spent an hour reading through old threads about this issue, lots of good info but just need a bit of input to clarify what's next.
    If all levels and temps are fine but warning light still comes on is it OK to run the car to test when rad fan kicks in etc.
  • tajgreidotu
    • May 2008
    • 324
    • Country: Spain
    are u sure its the coolant warning?
    If yes, then it should be a expansion bottle faulty sensor or shortcircuit in the wiring harness
    • Rikki Kitto
      • Feb 2010
      • 6276
      Just bought a new bottle and cap from Audi
      • Condor
        • Jul 2004
        • 424
        Did this fix the problem? was the warning light/buzzer on all the time? I have a similar problem at the moment, the warning lamp/buzzer is NOT on all the time, the coolant level is ok, engine temp ok according to gauges....is there anyway of testing the coolant bottle switch? ..cheers Condor
        :wave: :thumbs:
        • mike74
          • Apr 2014
          • 615
          have you tried unplugging the MFTS to see if that cancels the light?
            Could also be MFTS
            EDIT: D'oh! Too slow
            • Condor
              • Jul 2004
              • 424
              Originally posted by Error404
              Could also be MFTS
              Thanks guys, No I've not tried unplugging MFTS... warning only comes on when the engines warmed up..and goes out on and off ...I need it to play up when I'm home and can try different things to track down the problem .. the engine doesn't appear to be overheating....
              I have found several threads here since posting my original message, seems like this happens quite abit ..
              :wave: :thumbs:
              • Fat Audi 80
                • 10547
                If your fan works, watch the temperature gauge and wait for the fan to cut in. If your coolant level is ok and the fan is working there is no danger of damaging your engine.
                If this was not doing it before exp bottle change, I would suspect the new sensor.
                The Perfectionist
                • domas
                  • Oct 2014
                  • 307
                  • Country: Lithuania
                  very typical MFTS faulure mode.
                  did your aircon stop working as well? it did on mine. But the sensor was perfectly spot on, but it did send false overheat signal to ecu and climate ctrl head
