Evening lads, any suggestions on this ? Spec:
Rs turbo,manifold,injectors,inter cooler, air box ,3 inch full system with only 1 silencer high boost chips (1.9 bar) , 3bar vmap and r201 resistor mod on ecu,samco hoses and new vacuum lines. I tested the ecu in ather car and it went really well
Car was boost leak tested recently and found a leaky tb hose, adjusted and instantly improved boost from 1.3 to 1.5 bar. I say 1.5 bar, but that is a struggle...the boost gauge flickers and you feel the car holding back.
Other faults are: oil pressure warning comes on, I know it's the switch and will be fitting my new one as soon as I find time.i know they would appear unrelated but could this be contributing ? Nothing shows when put on a scanner
My main question is (if we assume the the boost system is airtight ) could this be electrical at all ? Maybe wgfv even though it appears to be quite new, maybe fuel pump related as its still on a stock s2 pump
Any help appreciated
