Mis-fire
  • AndyP
    • 6049
    Originally posted by UrS4boy
    The good news: Yay!! It runs and boosts!!
    The bad news: We don't know what the issue is/was. Injector wires, plugs or bad ground. Oh well. It runs.
    I'm pretty certain it was the injector plugs, as std they have a cartridge that holds the pins in place, that should look like this
    Two of mine were brittle and broken and looked like this
    This was allowing the pins to move around at possibly not connect to the injector correctly. The new plugs I used are a one piece design and don't have this pink insert
    I'm tempted to put the other plugs back in to proove this but then again I just want to drive it now!
      Originally posted by AndyP
      I'm pretty certain it was the injector plugs, as std they have a cartridge that holds the pins in place, that should look like this (photos)
      There, now we learned something. I am stealing your photos Andy (credit to you) and adding them to my injector post. (Thanks).
      Dave F.
      • AndyP
        • 6049
        Dave F.
        No problem, steal away
        • Tonks4x4
          • Nov 2005
          • 3062
          You forgot to mention blowing the dust off the wastegate cap!!!!!
          and giving it a wipe with an oily rag.
          I am sure it was this that cured everything.....
          Audi Nut!!!
            Andy: Was the PN of the new one-piece two-pin connector still 443906232 (Item 11 in the diagram below) or do they have a new PN for the one-piece connector?
              Early (draft) version of an injector connector issue post
              I will update this as needed (e.g. PN for the one-piece connector).
              Thanks Andy for finding this issue and posting up the photos.
                You can buy the single piece two pin connector aftermarket, it is generic 2 pin female Junior Power Timer connector
                • Tonks4x4
                  • Nov 2005
                  • 3062
                  Get them from here....
                  Audi Nut!!!
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    #54
                    Andy, shame on you for not isolating the problem.
                    I bet it was the earth. Then again, it could've been Tonks' oily rag. Now we'll never know for sure.
                    When the inner plastic broke up on my injector connector, I could tell which cylinder was not firing, as it was doing it from idle when I wiggled the cable.
                    I am glad you got it sorted, anyway
                    SS
                    • stocious
                      • Jul 2012
                      • 838
                      Glad you got it sorted!
                      1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
                      • AndyP
                        • 6049
                        I didn't get the plugs from Audi so I can't confirm the part number. I got them from ADI at Castle Combe a couple of years ago. There was a guy at the Autojumbe had a box full of them, it was the end of the day and he said for £5 I could have as many as I wanted! I knew they'd come in handy one day
                        • europeanme
                          • Oct 2005
                          • 3817
                          nice one Andy, I know you've been chasing this for a while now....
                          now will you take me out for a ride...
                          • AndyP
                            • 6049
                            Any time! I'll be in touch and we'll sort something out
