How to fit rs2 fuel pump
  • andyg plym
    • Nov 2006
    • 4646
    Just received an rs2 fuel pump with basket ( thanks dobin )
    I presume it's best to use the rs basket, but how do you get the old one out ? Is it a push fit? Clipped in etc ?
    Same with the wiring ? Any mods needed ?
    Finally, is the banjo on the s2 fuel line a straight fit to the rs pump ?
    Thanks all !
  • mcandmar
    • Apr 2004
    • 5118
    Basket rotates and lifts out, not an easy job and even more difficult to get back in. Have a look at Daves guide here http://www.s2forum.com/forum/showthr...t=c4+fuel+pump
    Hose will be a problem, i know for the 044 fitment i had to replace the original hose with an RS2 version. See the bottom of this thread http://www.s2forum.com/forum/showthr...&highlight=044
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • madpugger
      • Sep 2007
      • 1901
      I believe the coupe pipe fits.
      Have a look on my avant thread linked in my signature. The first thread lists which post for the fuel pump.
      Mike
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
        Audi S2, 90 and C4 Fuel pump removal pdfs
        Check out the C4-related pdf that mcandmar pointed you to: http://12v.org/urs/Fuel%20Pump%20Tes...eduresRev3.pdf
        Also there is the attached (based on a post from DougS2 at MRC) and the Audi 90 fuel pump removal guide attached.
        If you don't have to remove the basket, then you might be able to use this:
        • Rusty
          • 18953
          The diameter of the RS2 pump is the same, so you can use that and secure the RS2 pump using another method. Saves a lot of hassle.
          • andyg plym
            • Nov 2006
            • 4646
            What about the pipe actually connecting to the pump ? S2 are push on and use a jubilee clip but I guess I need to buy a banjo connection ??
            • Rusty
              • 18953
              Yes, you can use a banjo and jubilee or there is part that is designed for the job:-
              Amazing when the search function works properly
              • andyg plym
                • Nov 2006
                • 4646
                Nice one rusty !!
                • dobbin
                  • Jan 2011
                  • 164
                  fuel pump
                  andy i took that non return valve off and fitted it onto 040 pump which it does not come with one. if you run the car without a return valve fuel pressure drops off everytime you start car up you have to keep turning over until fuel comes up the line.
                  i found this out myself got my fittings on ebay
                  • andyg plym
                    • Nov 2006
                    • 4646
                    Hi mate don't forget my pm I sent to you
                    Just went to a local Bosch specialist and they had nothing I could use, any ideas where to look now ? He said I needed an m12x 1mm fixing.
                    Any ideas ? I just need the banjo and bolt don't I ? Or do I need more ?
                    • davenoble123
                      • May 2013
                      • 65
                      Dont Know
                      1996 Audi S2 Coupe ABY Emerald Green
                      • mcandmar
                        • Apr 2004
                        • 5118
                        In theory you could get a banjo and length of hose and make one up but lifes too short, just buy the RS2 hose and do it properly..
                        • andyg plym
                          • Nov 2006
                          • 4646
                          It's the bolt that I'm more concerned about....
                          • andyg plym
                            • Nov 2006
                            • 4646
                            Update: so I managed to find an elbow with the thread I needed for the pump, the elbow itself requires a larger diameter hose,is the rs2 hose bigger than the s2 ?
                            Also is it essential to have a fuel return valve ? The s2 doesn't
                            • andyg plym
                              • Nov 2006
                              • 4646
                              Bump
                              Want to fit this as soon as, the question is:
                              Do I have to fit a return valve to the pump ?
                              Thanks guys
