How to fit rs2 fuel pump
Dave and rusty thank you loads !
Really helpfull cheers lads !
Interesting, I know I can have an inline non return valve fitted but is it not needed ? On my pump I have an elbow not a banjo, the rubber hose will go directly to it, will this work ?Comment
OH....
Now you are calling it the "non-return valve". Before it was the "return valve". Just a slight (100%) difference.
Non-return valve = check valve = keep the fuel in the pressurized feed line to the fuel rail when the fuel pump is off. You *DO* need one. Somewhere.
The question now is whether your pump has one internally or not. I know that the 091G fuel pumps used on the UrS4/S6s have an internal check valve. I also know that the 044 Bosch Motorsport fuel pumps do NOT have an internal check valve and you need to add one on the discharge line (to keep the fuel rail pressurized for fast(er) restarts).
G6 Fuel Pump info: http://forums.quattroworld.com/s4s6/msgs/22623.phtml
Ok will get a part number tomorrow as its at work it's out of a stock s2 one if I recall its got pierberg stamped on it and looks the same as the one in your picture daveComment
Thanks for the info so question is do I need a valve on there ? I managed to find a brass inline one today, it won't look pretty but should work if neededComment
Going to say no to this one, the OE S2 pump has a built in one way valve and would bet the RS2 pump does too. Looking at the pic S4boy posted above i can see the output pipe is threaded into the main body of the pump, my bet is the valve sits below it.91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
ok here is what i have to work with....as mentioned its not pretty and to be honest i have my doubts....my friend at work sourced some bits, the problem is the thread on the rs2 pump,its not a common size and if i knew an 044 one would fit id of bought one off ebay by now...this is all i have found so far, a 90 degree elbow,pipe and not in the picture an inline one way fuel valve.
Will this work? As mentioned i can see its a bodge but......... in theory........
Attached FilesComment
