Having taken by S2 Avant out from hibernation - took for MOT and have a strange issue with the MPG reading (real time) on the MFA. It has done this previously and it always seems to be after it has stood for a long time.
Readings are very low, and decrease when I'm off the power and increase when on it so in reverse so to speak. But the range is quite small too so 7mpg off boost, on boost goes up by 5. Its not guzzling fuel and will probably settle down after 100 miles or so. Just wondering if anyone else has had similar problems. Cheers
