MFA MPG - strange readings
  • Trist28
    • Dec 2008
    • 725
    Having taken by S2 Avant out from hibernation - took for MOT and have a strange issue with the MPG reading (real time) on the MFA. It has done this previously and it always seems to be after it has stood for a long time.
    Readings are very low, and decrease when I'm off the power and increase when on it so in reverse so to speak. But the range is quite small too so 7mpg off boost, on boost goes up by 5. Its not guzzling fuel and will probably settle down after 100 miles or so. Just wondering if anyone else has had similar problems. Cheers
  • prj
    • Mar 2010
    • 6308
    There are two things which the speedo needs to calculate MPG.
    The vehicle speed signal from the output shaft of the gearbox (VSS), which is delivered in pulses, and a consumption signal from the ECU which is delivered as a duty cycle.
    Most likely you have a bad contact on the VSS wire or some cold solder joints in the clocks.
      Slightly off topic but Dmitri do you know how many pulses the ECU expects to see per revolution of the wheels? Is it 4 or 8?
      • prj
        • Mar 2010
        • 6308
        I don't know, never looked into it. Easy to find out though.
        • irishs2
          • Apr 2009
          • 2455
          Could it be 8 judging from the points on this ring?
          Eric
          95 S2 Avant under rebuild.
            Good pic, thanks. Saves me opening up my spare box
            Seems to correlate with the info dug up in this thread
              Not Dmitri (obviously) but I think I have the answer (8) based on this diagram (as documented in this G22 VSS post):
              • bluequattro
                • 2960
                My s4 is reading same after changing clocks
                Tick over mpg goes up to 18.5
                Light load driving I've seen 12 mpg
                Floor it and goes up to 20 mpg!
                Doing same miles per fill up though
                Brake light check works about 6 out of 10 when first start
                Must be same problem
                • Trist28
                  • Dec 2008
                  • 725
                  Thanks PRJ and UrS4Boy for some really useful info. However I popped out and its working so I'm going to live with it!
                  I've spent a good few hours sorting the number plate lights out - wiring issue somewhere in between rear quarter and fusebox - re-wired now
                  • Trist28
                    • Dec 2008
                    • 725
                    bluequattro - There is something quite cool about being able to nail it and MPG goes up
                    • bluequattro
                      • 2960
                      Certainly is, shame it's not reality though and it really does use fuel, unlike my tdi which sips like a Victorian lady
                      50 mpg vs 20 means I favour the smelly stuff at the moment
