Help!
  • pixsaudisex2
    • Sep 2004
    • 3110
    #31
    o had this on my brothers car was just a knackered coil causing the fuse to blow..
    • a25c
      • 259
      Originally posted by UrS4boy
      Which fuse was blown? The one in the red fuse holder or the one in the yellow fuse holder? My guess it was the yellow fuse holder and your problem is cracked coil wiring at the edge of the "20V turbo" coil pack plate, shorting out a coil or two, causing crap running and eventually the fuse in the yellow holder to blow.
      Apologies for my sketchy replies on this but I'm only getting small bits of info on this ...
      It was the yellow fuse holder that blew and the replacement Ecu did the exact same thing,so we are looking at a wiring problem now!
      96 UrS6
      96 UrS6 Avant
      Previous:
      '87 coupe quattro, '85 90 quattro
      '95 S2 Avant '89, 200 quattro 1b
      '00 Allroad 2.7T, '02 S6 V8 Avant
      '96 A6 2.5 TDI quattro Avant.
        Originally posted by a25c
        Apologies for my sketchy replies on this but I'm only getting small bits of info on this ...It was the yellow fuse holder that blew and the replacement Ecu did the exact same thing,so we are looking at a wiring problem now!
        Blowing the fuse in the yellow holder is Waaaaay better than blowing the one in the red holder. The yellow one will be the coil wiring, the red one would be an internal ECU issue. Coil wires are waaay easier to fix.
        Remove the "20V turbo" coil pack and examine the wiring for breaks in the insulation. There will, no doubt, be some and, probably, near the point where the wires enter the coil pack, where they can short out on the cam cover. The quick fix will be to wrap the cracked wiring with electricians tape. The better fix is replacing the wiring.
        • a25c
          • 259
          Solved!!
          It turned out to be a broken ignition switch...
          Thanks to everybody who replied
          96 UrS6
          96 UrS6 Avant
          Previous:
